Dissolves causing export errors
Brett Sherman
on Apr 23, 2013 at 2:41:14 pm
This has cropped up recently in a couple videos I've done. When exporting I'll get errors (fails at a certain frame number). What I've discovered is that it happens where there is a dissolve. If I delete the dissolve, it exports fine. If I put a new dissolve on the transition, the problem comes back. If I replace the dissolve with another effect it exports fine. Anyone have a clue as to what is happening or what I can do to solve the problem?
Loren Risker
Re: Dissolves causing export errors
on Apr 23, 2013 at 9:04:51 pm
Did you transcode your footage to prores?
OutOfFocus.TV - Original series, music videos, and entertainment for your couch.
Brett Sherman
on Apr 27, 2013 at 1:20:31 pm
No, it's the original codec - XDCAM in this case.
