FCPX bitches over Modified Files, and will not relink!
Morten Ranmar
on Apr 19, 2013 at 1:12:55 pm
I have not modified any files, but did export an XML, converted via XMLto7 and opened in PremierePro CS6 just to see if I was able to transfer a project. Now FCPX will not relink to some of the files!
If this issue is for real, I cannot use FCPX in my professional work!
- No Parking Production -
2 x Finalcut Studio3, 2 x Prod. bundle CS6, 2 x MacPro, 2 x ioHD, Ethernet File Server w. X-Raid.... and FCPX on trial
Jari Innanen
Re: FCPX bitches over Modified Files, and will not relink!
on Apr 19, 2013 at 1:29:17 pm
You should turn off the "Write XMP ID to Files" on import prefs in PPro.
More on this thread:
http://forums.creativecow.net/thread/344/19057#19058
Jeremy Garchow
on Apr 19, 2013 at 1:55:05 pm
QTEdit from Digital Rebellion will remove the XMP info and allow you to relink.
Morten Ranmar
on Apr 19, 2013 at 2:07:13 pm
Thanks, will try it.
I thought this issue was resolved. Will I have the same error if I edit an original in After Effects?
Jeremy Garchow
on Apr 19, 2013 at 2:41:01 pm
Yep.
Jeremy Garchow
on Apr 19, 2013 at 2:41:33 pm
By the way, you can turn off the XMP prefs in Pr and Ae.
Bret Williams
on Apr 19, 2013 at 7:43:50 pm
Yes. It's a global setting. Turn it off in either and it's off for both. The digital rebellion fixed it for me. 5 files at a time in the free trial.
Morten Ranmar
on Apr 19, 2013 at 8:16:27 pm
Downloaded QT Edit trial, and I can see it does remove Metadata - but files will still not relink!
Maybe I can reimport from card?
Bret Williams
on Apr 19, 2013 at 9:22:09 pm
You sure you removed the meta? I found the interface a little confusing and if I remember it was a two step process. I'm sure you'll have to quit and relaunch.
Morten Ranmar
Re: FCPX bitches over Modified Files, and will not relink! - SOLVED
on Apr 21, 2013 at 9:36:12 am
I resolved the problem by reimporting. But imagine if I had formatted the card, then I would have had to do most of the edits again. FCPX should allow me to force relink, like legacy used to offer.
Morten Ranmar
Re: FCPX bitches over Modified Files, and will not relink! - WARNING
on Apr 21, 2013 at 12:10:55 pm
Reimporting from archive has shifted the timing since last edit. This is a major BUG!
Jeremy Garchow
on Apr 21, 2013 at 1:39:57 pm
What do you mean by shifted timing?
Morten Ranmar
on Apr 21, 2013 at 3:26:32 pm
all the reimported clips had changes to in- and out points, so the timong was totally off.
Also all keyframes on the audiotrack had moved. I have used hours to correct it all again!
