Copying all clips between an and out point in a project
Tom Fox
on Apr 12, 2013 at 4:04:10 pm
It should be simple, but I can't figure it out.
I just want to copy all clips between an and out point (not just the ones on the primary storyline) and paste them into another project.
What's the trick?
T
James Cude
Re: Copying all clips between an and out point in a project
on Apr 12, 2013 at 8:25:49 pm
You can't do that precisely- what you can do is draw a lasso around the clips you want to copy. You may end up with an overlap of some clips you don't want outside of the in/out range but you can easily delete these once you copy/paste to the other project.
