remove blade cut (joing through edit)
Jason Brown
on Apr 4, 2013 at 11:25:56 am
Is there an easy to remove a blade cut? (besides cmd+z)
the only way I can see is to trim the clip to the next clip...but it still leaves 1 frame, so i have to lift from storyline (automatically fills with gap) then trim out the clip...then trim to the end.
Seems crazy for such a simple edit technique.
Neil Sinclair
Re: remove blade cut (joing through edit)
on Apr 4, 2013 at 4:53:53 pm
Assuming we're working in the primary, my method is to shift delete the clip after the edit, T for trim and drag over Gap clip. Long winded for an frequently used technique I know!
