Failed share
Mark Morache
Failed share
on Apr 1, 2013 at 10:58:05 pm
I've just started getting these errors like crazy.
"The share operation Master File has failed.
The operation could not be completed because an error occurred when creating frame 139 (error -1)"
At least it tells me where the problem is.
I changed a speed clip at the area of the suspect frame to force a re-render, but what's up?
Anyone know what an error -1 is? Or what I might be able to do to ameliorate this issue? Thx.
Don't live your life in a secondary storyline.
Mark Morache
FCPX/FCP7/Xpri/Avid
Evening Magazine,Seattle, WA
http://fcpx.wordpress.com
Mark Morache
Re: Failed share
on Apr 1, 2013 at 11:03:39 pm
Grrrr... this is frustrating. I tried it again and it got to frame 5109, which is a few seconds from the very end.
Double grrrrrr.
Mark Morache
FCPX/FCP7/Xpri/Avid
Charlie Austin
Re: Failed share
on Apr 1, 2013 at 11:19:50 pm
[Mark Morache] "Grrrr... this is frustrating. I tried it again and it got to frame 5109, which is a few seconds from the very end."
Try deleting *all* the project render files, and don't re render it before you export it. Sounds like corrupt render files, or (hopefully not) a corrupted master file. If that works, run disk warrior or at least disk utility and check your drives...
~"It is a poor craftsman who blames his tools."~
~"The function you just attempted is not yet implemented"~
James Boyd
Re: Failed share
on Apr 11, 2013 at 11:39:41 pm
I had the same error. This solved my problem.
I still am not at the root of what happened, but I do know I was having problems with an external disk that had issues as I was importing my files.
Deleting the render files and then exporting allowed me to export and send to compressor for transcoding, both.
Thanks for your help.
Mark Morache
Re: Failed share
on Apr 12, 2013 at 5:27:13 am
Yeah, I appreciate that we can get around the issue by deleting the render files, but honestly, I often work on projects where my export time matters. Exporting goes a whole lot faster when you're dealing with rendered media.
This is why I like to render as I go, whenever I step away for a minute.
Until they get this fixed, best practice for me is to edit, and render so I can see my effects in full res, then when I need to export, I DUPLICATE my project without render files, and EXPORT THAT.
Now I can keep editing my already rendered project without rerendering.
Mark Morache
FCPX/FCP7/Xpri/Avid
Tim Jones
Re: Failed share
on Apr 1, 2013 at 11:21:08 pm
The -1 error generally means an I/O write error. Is it possible that your render destination drive needs a bit of tender loving care?
Tim
Tim Jones
CTO - TOLIS Group, Inc.
http://www.productionbackup.com
BRU ... because it's the RESTORE that matters!
Jeremy Garchow
Re: Failed share
on Apr 2, 2013 at 12:23:33 am
Or is the drive full or near full?
Charlie Austin
Re: Failed share
on Apr 2, 2013 at 12:28:16 am
[Jeremy Garchow] "Or is the drive full or near full?"
Nope... plenty of free space.
Mark Morache
Re: Failed share
on Apr 2, 2013 at 5:16:39 am
Drive is fullish, but could use some cleaning up. Does anyone bother defragmenting drives anymore?
I'll try the render removal and see if that helps.
Mark Morache
FCPX/FCP7/Xpri/Avid
