Canon 5D Mark III Free Run Timecode in FCPX?
Carlos Mora
on Mar 31, 2013 at 10:56:46 pm
I'm not seeing Free Run timecode from my Canon 5D Mark III after importing into Final Cut Pro X. I can see the correct timecode for these files in Quicktime Player 7. I can't find any discussion of this problem anywhere. I'm sure I've either missed something simple. Can anyone help explain this, or even better, offer a solution? Help!
- Carlos
Bret Williams
Re: Canon 5D Mark III Free Run Timecode in FCPX?
on Apr 2, 2013 at 1:41:27 am
I think the only place you're gonna get TC from your Canon is by log and capture in FCP 7 with the Canon plugin. I don't get TC from them in X.
Carlos Mora
on Apr 4, 2013 at 10:27:56 pm
Thanks for your feedback, Bret. I find it really strange that Apple's own Quicktime Player 7 can read the timecode but FCPX can't. What a bummer.
Carlos Mora
on Apr 5, 2013 at 8:46:38 pm
I think I've found the source of the issue and it probably applies to any camera that does not embed a reelname into the metadata. While researching a solution, an editor I spoke to recommended I check out QTChange from VideoToolShed in order to add TC to my files. Reading the product description page, I came across this statement:
"FcpX only reads timecode if there is a Reelname present.
QTchange is now FcpX compatible, but you cannot leave the reelname empty!"
Looking through my media, I found this to be true of any clip that did not have a reelname at the time of import, including Canon and DriftCam files. After running the clips through QTChange and simply adding a reelname to the metadata, FCPX could suddenly read the time-of-day TC embedded in the clip.
