rendering compund clips
Julian Bowman
on Mar 22, 2013 at 10:26:42 am
I may be wrong but it appears that if i break a project into sections, edit each in a timeline, compound clip the sequences and then pop them in a play all timeline, that when I render one of the initial sequences it doesn't render the compound clip version in the timeline. This also appears visa versa. is this correct?
Cheers
David Battistella
Re: rendering compund clips
on Mar 22, 2013 at 1:47:42 pm
Check your sequence render settings to make sure you are rendering to the quality that matches your output quality preferences.
David
______________________________
The shortest answer is doing.
Lord Herbert
http://www.davidbattistella.com
