Event and Project sharing variant?
James Culbertson
on Mar 21, 2013 at 5:38:15 pm
If I ingest a camera archive and a collaborator ingests a camera archive, would the resulting event folders be considered to be mirrored such that project sharing would work properly?
I did a quick test here with two separate drives (and a couple of DSLR clips) that worked. But I wonder if it works more universally.
James Cude
Re: Event and Project sharing variant?
on Mar 21, 2013 at 9:53:23 pm
Can you be more specific? Generally speaking if you and a colleague ingest the identical media and don't alter it you should be able to link projects that way. Ideally though you would share the same media and one person ingests and then sends an Event to make it perfect.
