Changing clip connection point
Keith Koby
on Mar 20, 2013 at 2:12:49 am
Not sure what the problem is... Sometimes when we attempt to change the clip connection point by command-option clicking the connected clip at the new point where we want the connection, nothing happens. Is there a trick to get it to work consistently?
Matt Trubac
Re: Changing clip connection point
on Mar 20, 2013 at 4:01:28 am
Is it possible the clips are in a secondary storyline? If so, you need to command option click the storyline, as the clips don't connect, the storyline does.
Keith Koby
on Mar 21, 2013 at 1:27:31 am
No. They're just regular connected clips.
