FCX and 720p24
Tom Brooks
FCX and 720p24
on Mar 18, 2013 at 1:29:30 am
I find that if I set my Kona LHe Plus to 720p59;94 and then enter a FCX project that is 720p23.98, it plays with a halting stutter. If I exit FCX and switch the Kona LHe Plus to any 1080 format, it looks OK. It ain't supposed to work that way, is it? Am I missing something here?
Oliver Peters
Re: FCX and 720p24
on Mar 18, 2013 at 11:48:01 am
In FCP X the KONA or Decklink card settings must match the project. X doesn't add pulldown like FCP 7 did. You might check if there is a cross-conversion setting that works.
Oliver
Orlando, FL
http://www.oliverpeters.com
Tom Brooks
Re: FCX and 720p24
on Mar 18, 2013 at 12:22:49 pm
When I use1080psf23.98 it plays fine. So the Kona is taking the 720p23.98 and cross converting to 1080psf23.98 for me. It also works if the Kona is set to 1080i though. So the Kona is adding pulldown, I assume, to get to 1080i. Why can't it do that to get to 720p59.94? As long as it works, I don't really care. It's just unintuitive to set the Kona to 1080 when the project is actually 720.
John Fishback
Re: FCX and 720p24
on Mar 18, 2013 at 10:22:43 pm
That freaked me out the first time. Someone here suggested using 1080psf23.98 and that's been working fine with no issues. The above explanation makes sense.
John
MacPro 8-core 2.8GHz, 16 GB RAM, OS 10.7.4, QT10.1, Kona 3, Dual Cinema 23, ATI Radeon HD 5870, 24" TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
FCS 3 (FCP 7.0.3, Motion 4.0.3, Comp 3.5.3, DVDSP 4.2.2, Color 1.5.3)
FCP-X 10.0.7, Motion 5.0.6, Compressor 4.0.6
Pro Tools HD 10 w SYNC IO & 192 Digital I/O, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec DSP Monitors, Prima CDQ120 ISDN
