export to compressor all exports in single "document"
adam chesbrough
on Mar 6, 2013 at 2:49:25 am
I have jobs where I have up to 100 exports (1 minute videos each). The fastest (most efficient ie single encoding setup) way I have found is to:
1. send to compressor
2. Setting: Apple ProRes 422 (or uncompressed 8-bit)
3. New Job with target output (settings for this job are whatever I need the final encode to be)
My issue is that every time I "send to compressor" it adds that "project" to it's own "document". I would prefer that they are all in one "document". As it stands I need to unpin the documents and then drag the projects into the one "document".
Obviously batch send to compressor would be ideal but there is no batch exporting, sending, or sharing in FCPX.
The first image is what compressor currently does and the second is what I want it to do (on a side note anyway to add custom keyboard shortcuts??
Macbook Pro Retina: 2.6GHZ i7, 16GB RAM 1600MHz DDR3, GT 650M 1GB RAM
Hackintosh (Sandy Bridge): i5 2500, 16GB 1333MHz DDR3, Nvidia GT640 2GB RAM
OWC 4TB RAID0 (using esata)
Tempo SATA Pro ExpressCard/34 (6Gb/s)
Echo ExpressCard Pro Thunderbolt Adapter
Loren Risker
Re: export to compressor all exports in single "document"
on Mar 6, 2013 at 8:03:51 pm
I don't think there is a way. FCPX desperately needs a batch export option. I'll be very surprised if it doesn't come in the next version.
OutOfFocus.TV - Original series, music videos, and entertainment for your couch.
© 2018 All Rights Reserved
