Add Extra text layer to Title?
Martin Phillips
on Mar 5, 2013 at 4:33:35 pm
Ok - so this is my first FCPX project so finding my feet a bit ......
Just wondered if it's possible to add another text layer to a Basic or Custom title? I just want to be able to move the text lines around separately. Presumably if not I can just stack up title tracks? Thanks in advance.
Martin Phillips Freelance Cameraman / Producer / Editor
Chesham, Buckinghamshire, UK. http://www.videodvdmaker.co.uk
Lawrence Eaton
Re: Add text layer to Title?
on Mar 5, 2013 at 6:48:28 pm
Martin,
Stack them up as you like; Edit their parameters, if you wish/ need and then right click to form a compound clip for efficiency's sake.
This might illustrate it in a simpler way: 5588_titles.png.zip
Lawrence
Martin Phillips
on Mar 6, 2013 at 10:07:49 am
Thanks Lawrence - that was just the job!
Brett Sherman
Re: Add Extra text layer to Title?
on Mar 10, 2013 at 12:44:36 pm
You can right-click the title and open it in Motion. Then you can add as many text fields as you want and save it as a new title. If it's a one-off then stacking is not a bad idea. But, if you need to do it continually then making a custom title will save you time.
