Inadequate Audio. Whats the reason?
David Powell
on Feb 25, 2013 at 5:24:43 am
What are the limitations of FCP's sync feature for multiclips? I have had video and audio only clips that I lined up in angle editor with extremely clean audio right on top of the matching sound and I get this message after a long unsuccessful syncing. Is there a problem mixing audio with various sample rates? Are there video limitations also?
T. Payton
Re: Inadequate Audio. Whats the reason?
on Feb 25, 2013 at 2:37:10 pm
[David Powell] "I get this message after a long unsuccessful syncing. "
Can you post again. We don't see the message.
T. Payton
OneCreative, Albuquerque
David Powell
on Feb 25, 2013 at 7:46:51 pm
That's strange I can see it. But here it is again:
T. Payton
on Feb 25, 2013 at 7:56:52 pm
Is there a picture of an error message that you are trying to post? If so we're not seeing it.
If not you mentioned a message, what does the message say?
T. Payton
David Powell
on Feb 25, 2013 at 8:31:16 pm
Ooh sorry. No I don't have a picture. That is the exact wording after the failed sync though. "inadequate audio". fortunately it was easy to manually sync this sound file. It's a problem though when it's multiple video files, which happens often. I figured there was some limitation in mixing formats that I may not be aware of.
T. Payton
on Feb 25, 2013 at 10:12:17 pm
I haven't seen or heard of any audio format restrictions in FCP X. I have synced a large amount of double system sound and never had a problem.
Are the audio/video files out of ordinary? What are they exactly?
T. Payton
