Paste and Match Style
Dave Gage
on Feb 24, 2013 at 9:32:28 pm
These days, I seem to spend most of my life adding lower 3rd annotations to instructional videos. I've archived many of the more common statements, so I don't have to re-think and re-type them every time.
Up until a week ago, it was a major pain copying and pasting in quotes because to keep my formatting, I would need to do it via the Inspector in the Text field, so lots o' clicking to get it done. Out of the blue, I decided to right-click on the selected text within the viewer and I found an option called "Paste and Match Style". What a time saver for me!
This option doesn't exist in the menus nor could I find it available to map a keyboard shortcut to it. I'm still on 10.0.4, does anyone know if this command is found in the Edit menu in 10.0.7 or available to map as a keyboard shortcut?
Dave
Jeremy Garchow
Re: Paste and Match Style
on Feb 24, 2013 at 10:12:12 pm
That's a finder operation, just like the spell check.
You'd map it through Finder not through fcpx.
Gerry Fraiberg
on Feb 24, 2013 at 10:18:42 pm
Nice find:)
- Gerry
Dave Gage
on Feb 24, 2013 at 10:54:57 pm
[Jeremy Garchow] " That's a finder operation, just like the spell check.
You'd map it through Finder not through fcpx."
Okay, that's doable. I do like the Apple default "Shift-Option-Command-V" to paste and keep the formatting where you are pasting into. I really thought based on how this command works in Mail and other apps, that it would work here or I could map it in the Keyboard Commands, but no such luck. In the meantime, right-clicking works fine.
I thought maybe this was available in a more current version of FCP X and would give me a reason to upgrade.
Dave
Jeremy Garchow
on Feb 25, 2013 at 1:39:55 pm
[Dave Gage] "I thought maybe this was available in a more current version of FCP X and would give me a reason to upgrade."
It is not as it's really a function of the Finder and not FCPX.
Although, not all applications will receive this global shortcut.
Dave Gage
on Feb 25, 2013 at 8:36:06 pm
Jermy,
I know there are 3rd party apps out there that allow you to do stuff like this, but I'm not sure I care enough to spend time on it. As I said, now that I know it's there, I'll just right-click. I use the "Shift-Option-Command-V" all the time and was hoping there was an easy way to do it here.
Dave
