Change Multicam Clip Properties?
Winston Hoy
on Feb 22, 2013 at 5:25:11 pm
I've got a multicam clip w/ three camera angles that we've already cut, but are finding that we set the resolution of the multicam clip incorrectly. Is there anyway of adjusting the resolution of a multicam clip? Reason being we've got footage from one camera at 720 and two cameras at 1080 and we'd like to have the multicam clip changed from 1080 to 720.
Winston Hoy
Re: Change Multicam Clip Properties?
on Feb 22, 2013 at 9:14:20 pm
Found it! With the multicam clip selected in your events browser, open your inspector tab and at the bottom right is a cog dropdown menu with an option of "Multicam clip settings" and from there you can edit the resolution of the multicam clip, change render settings, but can't change frame rate, most likely because you've got clips on that timeline.
