FCPX & Premiere export/xml/ANYTHING
adam chesbrough
on Feb 19, 2013 at 10:35:47 am
I don't care how it happens...I need to get edited footage from adobe premiere into FCPX.
XML is greyed out
all exported files will not play in FCPX (I've even tried to export as pro res in adobe as it is on a mac...only audio, no video)
I can't understand why if something is exported as a ProRes file that is won't play in FCPX.
Does anyone have a work flow out there?
Macbook Pro Retina: 2.6GHZ i7, 16GB RAM 1600MHz DDR3, GT 650M 1GB RAM
Hackintosh (Sandy Bridge): i5 2500, 16GB 1333MHz DDR3, Nvidia GT640 2GB RAM
OWC 4TB RAID0 (using esata)
Tempo SATA Pro ExpressCard/34 (6Gb/s)
Echo ExpressCard Pro Thunderbolt Adapter
Oliver Peters
Re: FCPX & Premiere export/xml/ANYTHING
on Feb 19, 2013 at 2:32:09 pm
[adam chesbrough] "I don't care how it happens...I need to get edited footage from adobe premiere into FCPX. "
Purchase 7toX for Final Cut Pro (Mac App Store) from Intelligent Assistance.
Export Premiere Pro XML. Import into FCP 7 and export an FCP 7 XML. This step may be unnecessary, but often improves the translation. Import that XML into 7toX (or import the PPro XML directly). Send it to FCP X. The edited sequence will show up as a compound clip in a keyword collection within the Event.
- Oliver
Orlando, FL
http://www.oliverpeters.com
T. Payton
on Feb 19, 2013 at 3:27:41 pm
Are you saying that the media files you use in Premier can't be imported into FCP X? Are those files playable in Quicktime X?
Premier can play several formats that FCP X can't. Thusly you might need to transcode.
If you just need to export your complete show, you might try a different codec. Perhaps something is becoming corrupted with the ProRes files. Try PhotoJPEG, or even uncompressed.
T. Payton
OneCreative, Albuquerque
Oliver Peters
on Feb 19, 2013 at 4:08:35 pm
Do you also have Motion and/or Compressor installed on this machine? I believe that's needed in order to write ProRes files, not just FCP X. But I could be wrong.
- Oliver
Orlando, FL
Al Bergstein
on Jun 24, 2013 at 12:35:32 pm
Did you figure this out?
Al
