Cinema Tools Luminance Shift
Dale Robinson
on Feb 9, 2013 at 10:05:38 pm
When conforming 60p to 24p in Cinema Tools is it typical to get a slight luminance shift ?
I made a copy of a 60p clip, conformed the copy and then matched into the original
and the luminance dropped on the conformed clip.
Jeremy Garchow
Re: Cinema Tools Luminance Shift
on Feb 10, 2013 at 12:12:21 am
Are you seeing this after importing or just in QT?
If you are simply conforming frame rate in CT, there's no change to the file except it gets a 23.976 frame rate.
New media is not created.
Dale Robinson
on Feb 12, 2013 at 12:04:48 am
Thanks Jeremy, Not sure why I got the luma shift but I tried it again and it worked fine.
