Cant Relink Red .r3d files in FCPX 10.0.7
Curry Leamen
on Feb 9, 2013 at 5:26:26 am
I’m having some serious problems relinking some footage.
I’m working on a big job that I wanted to bring home for the weekend to work off my personal machine. I copied my event and project folders as well as a folder containing all raw footage on to a raid and brought it home.
The Event has 5D, gopro and Red Epic footage being used. When I started the Event on the computer at work, I chose not to import the files into the FCPX event, i let FCPX reference a folder containing all raw footage.
When I got home, plugged in the raid and opened the event, expectedly I had to relink all the footage files. Everything from the 5Ds and go pros reconnected perfectly but NONE of the Red Epic files will reconnect. I get the ” The original file had audio, but the new file doesn’t.” error.
This doesn’t make sense, I copied the entire Raw footage folder over as is as well as the Event and project folders. Even the proxies for the RED footage reconnect fine. The RED footage never had audio so I have no idea why its telling me that.
Any insight would be much appreciated!
Curry
Eric Santiago
Re: Cant Relink Red .r3d files in FCPX 10.0.7
on Feb 9, 2013 at 6:42:28 am
In some cases I just re-import the files and they seem to link afterwards.
There is a better way of doing this but Im no where near my FCPX box at the moment.
Zef Fiola
on Jun 11, 2013 at 7:53:33 pm
Be sure to install RED APPLE WORKFLOW INSTALLER found at https://www.red.com/downloads
That's what fixed this exact same issue for me.
cheers,
ZEF
http://www.vjzef.com
