offline files not copied to Event folder - no hard drive location info in the event or the properties tab
Dave Jenkins
on Feb 4, 2013 at 6:12:46 pm
I have files that are offline and not copied to the Event folder and there is no hard drive location information in the event or the properties tab to know which hard drive these files came from.
Is there a solution to this?
Dajen Productions, Santa Barbara, CA
MacPro Two 2.66GHz Quad Core - AJA Kona LHe
FCS 3 OS X 10.7.4
FCP X, Adobe CS6, Logic Pro, Squeeze, Filemaker
Jeremy Garchow
Re: offline files not copied to Event folder - no hard drive location info in the event or the properties tab
on Feb 4, 2013 at 7:22:01 pm
[Dave Jenkins] "Is there a solution to this?"
Not without a manual search, no.
It is possible, if using aliases, that the file could have moved. If you "Show File Status" in the inspector, it will show you the filename of the offline file. Do a spotlight search with one of the filenames and see if it has changed directories.
