how do you create this effect? ghost effect?
Daniel Martinez Hernandez
on Jan 28, 2013 at 7:41:28 am
how can you create this effect some sort of ghost effect? starts at 8 seconds when he's in the mirror
Loren Risker
Re: how do you create this effect? ghost effect?
on Jan 29, 2013 at 10:59:34 pm
To get you started:
Duplicate the portion of your clip where you want the ghosting to occur. Add it directly on top of the original clip (command-c to copy, alt-v to connect to the storyline)
Slip it forward or backwards a few frames. Change the opacity of the top clip to around 50%.
OutOfFocus.TV - Original series, music videos, and entertainment for your couch.
John Fishback
on Feb 12, 2013 at 5:45:24 pm
If you have Motion 5 it has a Trail Effects that will do what you want. If you don't have it, Google "Trail Effect for FCPX" and see what pops up.
John
MacPro 8-core 2.8GHz, 16 GB RAM, OS 10.7.4, QT10.1, Kona 3, Dual Cinema 23, ATI Radeon HD 5870, 24" TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
FCS 3 (FCP 7.0.3, Motion 4.0.3, Comp 3.5.3, DVDSP 4.2.2, Color 1.5.3)
FCP-X 10.0.7, Motion 5.0.6, Compressor 4.0.6
Pro Tools HD 10 w SYNC IO & 192 Digital I/O, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec DSP Monitors, Prima CDQ120 ISDN
