I'm getting WAY too many flash frames. Anyone else?
Robert Bracken
on Jan 18, 2013 at 7:48:47 pm
It seems that when I hit the "e" key to add video at the end it's creating a small flash frame.
My projects are littered with these and I'm lucky that most of my videos are less than 5 minutes. That makes finding them take less time.
Is anyone else having these problems?
Jeremy Garchow
Re: I'm getting WAY too many flash frames. Anyone else?
on Jan 18, 2013 at 8:56:51 pm
I have not seen this problem. But.
The timeline index, I would imagine, would be a good place to find these.
Are all of your clips the same frame rate?
Jeremy
Mike Damian
on Jan 18, 2013 at 9:58:04 pm
Do you have snapping turned on?
Robert Bracken
on Jan 18, 2013 at 10:11:00 pm
Yes I have snapping turned on.
But I'm pressing the "end" button to add video to the end. Why is fcpx giving me flash frames?
Jeremy Garchow
on Jan 18, 2013 at 10:13:23 pm
is your footage the same frame rate as your timeline and is all of your footage the same frame rate?
Robert Bracken
on Jan 18, 2013 at 10:14:17 pm
Yes it is 29.95
Mike Damian
on Jan 18, 2013 at 10:27:56 pm
are you using MFX files by any chance? I've had problems with them creating black flash frames before. SO I had to convert to ProRes 422.
Robert Bracken
on Jan 18, 2013 at 10:32:16 pm
I don't know what that is. I selected "optimized my clips" when importing.
Mike Damian
on Jan 18, 2013 at 10:38:37 pm
What camera did you use to film your footage?
Jeremy Garchow
on Jan 18, 2013 at 10:40:32 pm
If you get a flash frame every time you hit e, you should try trashing your prefs or reinstalling.
Nick Toth
on Jan 19, 2013 at 3:10:02 pm
I was recently doing some audio editing with the source clip in the primary storyline and no other clips in the project.
I cut out a section and wanted to repeat it several times so I did what I would normally do and option-dragged the clip to make and place the duplicate. I kept getting one frame audio clips at the end of the option-dragged clip.
This is not normal behavior and I have not been able to follow up on it yet but maybe there is a bug in there somewhere and it's related to what you're seeing.
NT
Bret Williams
on Jan 20, 2013 at 6:26:10 am
So did you edit the audio at the sub frame level? If the audio extended even 1/100tg of a frame past the video, then you'd have a flash frame because you can't paste the video on the subframe level.
