import FCP7 project into FCPX
Piotr Raczko
on Jan 10, 2013 at 10:16:32 am
Hi again.
How can I import my FCP7 projects into FCPX? Is it possible? I can't find any open / import project in the menu.
Please help, thanks.
Paul Figgiani
Re: import FCP7 project into FCPX
on Jan 10, 2013 at 11:55:18 am
http://assistedediting.intelligentassistance.com/Xto7/
Paul Figgiani
on Jan 10, 2013 at 9:14:09 pm
Wrong link up top:
http://assistedediting.intelligentassistance.com/7toX/
Bret Williams
on Jan 11, 2013 at 5:39:53 pm
But don't expect too much from it. Any titles won't come across. Keyframing, cropping, etc. will sorta sometimes partially be ok. Transitions aren't always right or compatible. Speed changes can throw it off. Audio, especially with the new changes in 10.0.6, has been very inconsistent depending on your workflow.
But if you're looking to take a basic cut in 7 and bring it into X it will do the trick. It's cheap enough to give it a whirl and see if it suits your needs.
