Some clips don´t match from FCP7 to scratch6
COW Forums : Assimilate Scratch
Pepo Razzari
on Jul 6, 2016 at 10:30:26 pm
Hi there.
I am trying to get a secuence from a fcp7 to scratch 6.
I tested both edl and xml methods. I load first the xml and then start matching from folder. This way some clips dont produce any match, even when they are in the same folder as the rest of the clips and the file names match with the xml names.
If I try to reverse assemble using an edl (load all the footage to construct and then the edl) all the slots match the first clip loaded in the construct, instead of matching the right media.
What is going on here? I guess there must be some timecode issue. Footage is sony a7s recorded to a shogoon4k recorder in prores hq 4k at 23.976 fps. It is confusing many of the clips match just fine using the xml way, and inspecting their metadata in fcpro, there does not seem to be any difference with the clips that do not work.
As a test, I borrowed a friends machine with after effects and it loads the xml and links the media just fine.
Downloaded scratch 8 trial and it still has the same problem..
Thanks in advice for any help you can think of.
© 2018 All Rights Reserved
