Assimilate Scratch 8 - Menu issues
COW Forums : Assimilate Scratch
Ilker Cevikkaya
on Mar 14, 2015 at 10:02:24 am
I'm just new in Assimilate Scratch. I'm trying to use demo version to learn, thanks to Assimilate Inc. I have some problems about some tools:
1- My version menu doesn't work. It's disabled.
2- In trays Add+, Apply+ menus are also disabled. I just use only Add and Apply.
Is it because it's demo version?
My system is Imac, Late 2013 and Mac OSX Mavericks
Daniel Esperanssa
Re: Assimilate Scratch 8 - Menu issues
on Mar 16, 2015 at 3:17:13 am
Hi Ilker,
There's no limitation in the trial Scratch version. It is fully operational.
Most likely you are in Play Shot mode and not in the context of a timeline. In that case "Versions" will be grayed out.
What to do:
Display the full construct. You timeline is the bottom line in the construct.
You can either:
- park the Play head under a shot and hit the Play button underneath
- don't select any shot and just hit the Play button
In both cases, Versions, Add+ etc will be available.
Also please have a look at the tutorials available on https://scratchweb.assimilateinc.com/ in the "Public" section.
You'll find the "Getting Started" video and many more, including the "Gallery" video etc
Same tutorials are also available on https://vimeo.com/assimilateinc
Hops this helps,
Cheers
D.
Ilker Cevikkaya
on Mar 17, 2015 at 10:10:07 am
Hello Daniel,
Thanks for your helpful infos. By the way as a da vinci colorist, I should say that Scratch is like an ocean :)
Daniel Esperanssa
on Mar 22, 2015 at 8:17:47 am
Hi Liker,
This video should be of some help then ;-)
Cheers
D.
