Export Jpg2000 from scratch 8
COW Forums : Assimilate Scratch
Julian Alto
on Jan 30, 2015 at 9:56:24 pm
Hello,
We are new in V8, I´m exporting a jpg2000 xyz sequence but the frames are to big for DCP, more than 5 megas each frame when generally are in 600k, in version 7 exported ok, I tried to change settings in advanced panel, but nothing happens, any help?
best regards
Daniel Esperanssa
Re: Export Jpg2000 from scratch 8
on Feb 2, 2015 at 4:50:18 am
Hi Juan,
Ensure you are on latest build (8.2 build 846).
How do you wrap the Jpg2K files into MXF ?
Into Preferences/Advanced/, "Jpeg2000 Encoding Format" should be set to "0" (DCI Compliant).
D.
Julian Alto
on Feb 3, 2015 at 1:57:25 pm
Hello, thanks Daniel for your response. Yes it´s the last version and last build.
I use Open DCP, but yes is set in 0 DCI compliant.
But still the frames size is to big.
any idea?
best regards
Julian Alto
on Feb 3, 2015 at 3:39:38 pm
Hello, I found the solution, the JPEG encoder must be On and set in 75. And now the j2c frames size is correct for DCI.
best regards,
Scratch 8 is great!
