How to apply construct versions to slots?
COW Forums : Assimilate Scratch
Ziryab Ben Brahem
on Aug 2, 2014 at 9:02:40 pm
I have a build a series of looks and saved them as "versions" within the construct. But when I change the version from slot to slot, it applies the color matrix to the entire construct, rather than the single slot. However, I wish to apply different versions of the construct to the individual slots. How can I do that?
The clip is a prores 4444 scan from a 16mm negative mixing several shots and scenes. I used scratch's build-in editor to splice up the shots into separate pieces using the "split" tool.
Thank you!
Daniel Esperanssa
Re: How to apply construct versions to slots?
on Aug 3, 2014 at 11:24:54 am
Hi Ziryab,
When you "splice" a single file into separate slots, the first thing to do is apply [All + Fits I/O] in the Construct Media menu.
That will ensure that each shot t is limited to the length of the slot.
That should do the trick.
Cheers
D.
