AVID DNXHD36 transcode problem
COW Forums : Assimilate Scratch
victor casasola
on May 6, 2014 at 9:35:11 am
I have an issue with scratch v8; I'm trying to output DNxHD 45MXF media, everything it`s ok until the last part of the transcode, which is something very annoying (after waiting for some minutes, of course). The software gets stuck at the end, cursor spins around and it can be at this stage for hours...
Closing scratch and re-opening, but the transcodes are with errors.
I have tried with a transcode of the same material in QT, and everything it`s right. Even with different material from different cameras, always makes the same...
I am quite stuck at the moment. I have tried to uninstall and reinstall and it`s the same...
Any idea why this happened?
Do I miss some codec from avid?
Daniel Esperanssa
Re: AVID DNXHD36 transcode problem
on May 14, 2014 at 6:46:05 am
Hi Victor,
Not sure what build you are on and which operating system but i suppose you are on Mac where there was an issue on build 802.
This has been fixed in later releases.
© 2018 All Rights Reserved
