Conforming R3D files without original path
COW Forums : Assimilate Scratch
Martin Led
on Apr 7, 2014 at 6:54:20 pm
I just finished editing a short film and I created an EDL to work the coloring on Scratch. The problem is the production team gave me the data outside the original directory, so I have all the .RDM folders in a folder called RAW. Naturally, Scratch doesn't recognize the EDL and I can't reconnect the media even though I edited with the RED proxy files.
What can I do to reconnect the EDL to the new directory?
Daniel Esperanssa
Re: Conforming R3D files without original path
on Apr 14, 2014 at 7:56:20 am
Hi Martin,
First would be to load all the media from the RAW directory.
Then load the EDL and it should match.
If you already graded proxies, then do a Ctrl+A on the proxies construct, "copy selection", navigate to the RAW construct and use "Paste Grade" from the Construct menu.
Let us know.
Cheers
Daniel
