Construct: Failed to write frame 0
COW Forums : Assimilate Scratch
Ritz Carltn
on Mar 31, 2014 at 4:13:14 am
I always have Construct failed as followings, any help really appreciate,
Ritz Carltn
Re: Construct: Failed to write frame 0
on Mar 31, 2014 at 7:03:24 am
Scratch Lab v8
Daniel Esperanssa
on Mar 31, 2014 at 9:54:06 am
Hi Ritz,
Try adding the QT export node after the main output (instead of using the same level).
- Select the existing default Output node
- Add the QT export
- Select a specific render folder (you can create one from the browser)
- Change file naming to ie: #sname.#.ext
Give this a try and let me know.
Cheers
Daniel
Daniel Esperanssa | Assimilate Europe Ltd.
Ritz Carltn
on Apr 1, 2014 at 3:18:46 am
Big Thanks,
It's working ^ ^
Daniel Esperanssa
on Apr 1, 2014 at 12:58:15 pm
Cool.
Thanks for the update.
Keep in mind dozens of tutorials are avaiable at vimeo.com/assimilateinc
Cheers
Daniel
Ritz Carltn
on Apr 2, 2014 at 1:19:55 am
[Daniel Esperanssa] "vimeo.com/assimilateinc"
Yup, I already did it and really helpful for me. ^ ^
