AJA KONA 3 DUAL LINK RGB
COW Forums : Assimilate Scratch
Jan Klonowski
on May 29, 2013 at 7:20:29 am
Hi Scratch users,
ive recieved an used kona 3 (not 3g) some day ago an tryin to setup an dualink rgb workflow but alwasy get a crashed image when selecting any rgb options in scratch (magenta broken lines) any ideas whats wrong ?
my setup is
kona 3 dualink (2sdi) to bmd hdlink dp pro to monitor whith displayport and to Scopes with loop through/3g sdi out
kind regards jan
Matthias Aderhold
Re: AJA KONA 3 DUAL LINK RGB
on May 31, 2013 at 7:29:19 am
Which driver-version of the Kona are you running?
Should be 10.3.2^^
Mazze
Jan Klonowski
on May 31, 2013 at 7:32:18 am
ive tried drivers 10.0.1 and 10.3.2 but no luck at all, but the other applications are fine with duallink rgb (cs6,etc)
jan
Matthias Aderhold
on May 31, 2013 at 7:39:47 am
Forgot to add: 10.3.2 on Windows, 10.4.2 on OSX.
Jan Klonowski
on May 31, 2013 at 8:25:52 am
hi mazze,
im on windows trided 10.0.1 and 10.3.2 with no luck at all.
others apps (like cs6) work fine with dl rgb 444
jan
Matthias Aderhold
on May 31, 2013 at 2:01:52 pm
Strange - not sure, what could be wrong.
Scratch did recognize the card properly, I suspect?
Note, that you always have to update the AJA Firmware accordingly to the driver.
After you installed the AJA-driver and rebooted, you should be prompted
to update the Firmware on the card itself.
If not prompted automatically, the update-tool (AJA Kona-Updater),
has been installed with the driver - execute it.
After it has finished updating the card, it is IMPORTANT,
that you SHUTDOWN THE PC AND UNPLUG POWER CABLE FOR AT LEAST 10 SECS -
otherwise, the firmware won't get updated.
If that doesn't help, get in contact with Assimilate support.
Cheers,
Mazze
Daniel Esperanssa
on Jun 27, 2013 at 8:49:30 am
If "RGB 10/444 DL" shows up in the SDI Settings, then driver is ok.
What Scratch build ?
Daniel Esperanssa | Assimilate Europe Ltd.
