Construct: Failed to write frame 0
COW Forums : Assimilate Scratch
Rob O'Connor
on Feb 24, 2013 at 3:04:24 am
I keep getting the error message 'Construct: Failed to write frame 0' when I try to output my footage using a DNxHD36 codec but if I output the same footage using a QT H264 I have no issues. I'm using Scratch 6.1
Can anyone explain why this is?
Kind regards
Matthias Aderhold
Re: Construct: Failed to write frame 0
on Apr 12, 2013 at 3:37:46 pm
Hi Rob,
most likely you have the #ext token in your output-filname specification included.
This doesn't work, when exporting Avid MXF.
To explain it in a simple way: The #ext token includes the file-extension
in the output-filname - so if you are exporting a Quicktime,
it will include a "mov" in your filename.
Now with the MXF-renderer - it not only renders MXF-files,
but aaf-files, as well.
So if you have the #ext token included, Scratch simply doesn't know,
which ext to render - aaf or mxf ;-) .
So simply delete the #ext out of your outputfilname-specification
and try again^^.
.. and I would have responded much earlier, if this crappy forum
would only have a normal, or at least reasonable thread-display...
Mazze
Sridhar Jayabalan
on May 31, 2013 at 10:15:11 pm
Hai Rob ,
Sorry for late reply ,now only i face the same problem. Now it working for me. It was a software error Dont mind it. just re install new version with ScratchAmtSetup and Assimilate CSP with Assimilator x64 Setup. Now it working.
Better go for Assimilator Scratch v6.1 723.
Thank u.
Matthias Aderhold
on Jun 2, 2013 at 12:02:01 pm
Better go for v7 build 751 along with AMT 2.4.0.2 ...
