Conform 50p footage in 25p project
COW Forums : Assimilate Scratch
Julian Argentina
on Sep 29, 2012 at 9:51:39 pm
I'm going to do the online of a feature film in AS. The footage was shooted in red 2k at 50p, but the finish is in 25p. How can set the best workflow?
The most part of the film is in real play and a few shoots in slow motion.
The edit was in FCP 7.
thanks for any advise!
best regards
Matthias Aderhold
Re: Conform 50p footage in 25p project
on Oct 11, 2012 at 9:02:14 am
If I'm not mistaken, a 50fps shot in a 25fps timeline should playback with 25fps, just dropping every second frame - but I could be wring on that one, please check first.
For the conform you should set up a copy of the original timeline,
setting every applied timewarp to be linear, or constant and export an XML from that one.
Then render out a reference-mov from the original timeline to eyematch all timewarps.
This is how I would approach this, only thinking about it quickly.
© 2018 All Rights Reserved
