Scratch Finish 7 How may GPU needed for F65 4k SQ 16bit debayer real time
COW Forums : Assimilate Scratch
Sanjiv Patel
on Sep 27, 2012 at 4:21:51 pm
I need to know how many GPU require for F65 4k SQ 16bit debayer real time work flow in Scratch finish (real time 24P F65)
when debayer F65 4K SQ 16bit Raw
Is it CPU or GPU base or Both?
Which GPU is Best to work with Scratch Finish 7 on PC 64bit?
what is takes viewing 2k with LM-2461W & AJA Kona 3G and processing realtime at full res DPX files?
Is their any System Spec to Build system for 4K 16bit files ?
Yes I do have Fiber Raid 24TB Read 2200 Mbps Write 1800 mbps using 2k 10bit file AJA system utility at 16GB file size
so don't even go there :)
Matthias Aderhold
Re: Scratch Finish 7 How may GPU needed for F65 4k SQ 16bit debayer real time
on Sep 28, 2012 at 10:22:53 am
Answer is quite simple:
Scratch only needs one GPU - multi-GPU is not needed and not supported.
Best card currently is a Quadro 6000.
As far as I know, the Sony SDK uses OpenCL for debayering on Win7 x64.
So, it looks like it's all done on the GPU ;-) .
Greetz,
Mazze
Sanjiv Patel
on Sep 28, 2012 at 12:56:58 pm
Are you sure about multi gpu not supported?
Does it need dedicated quadro 6000 gpu or it can be share as graphic cad plus gpu
If you have 2 quadro 6000 gpu how will you know which on is being used?
Is their any spec pdf i can learn more?
What is OPEN CL has to do with gpu?
thanks
Matthias Aderhold
on Sep 28, 2012 at 2:12:47 pm
Yep, sure about multi-gpu.
You only have to install one GPU - that's the good thing about Scratch - it get's more out of your hardware than others ;-) .
If you have installed two cards, it will take whichever is initialized first, I would guess - but I'm no developer.
F65 is usually debayered on GPU, as long as OpenCL is supported on GPU by OS / Card - which should be the case with Win7 x64 and Quadro 6000^^.
Daniel Esperanssa
on Oct 1, 2012 at 8:29:17 am
Hi Sanjiv,
Only 1 GPU is supported and 6000 is perfect for F65.
Sony F65 debayer method is explained on the Assimilate support site as well as the Drivers Chart page shows you the recommended drivers.
Scratch is fully GPU based, that's why it uses the GPU to debayer the F65 here. You can force the debayer to be done by the CPU by activating a variable in the sconfig file, but this would make sense here.
Most common bottleneck with F65 is the disk access. Don't rely on Aja utility. Run a Profile from within Scratch.
Cheers,
Daniel
Sanjiv Patel
on Oct 5, 2012 at 3:20:04 am
Run a Profile from within Scratch. ?
How any what does it do?
What is the current recommended graphics driver for quadro 5000 or 6000?
How do you know gpu is being use for f65 raw sq files ?
Daniel Esperanssa
on Oct 5, 2012 at 8:58:39 am
Sanjiv,
I think most of your questions have been replied in the previous post, except Profile.
Profile performs a series of benchmarks test to determine the capabilities of the system you are running SCRATCH on and is located in Player/Settings.
Details of the benchmarks and their meaning is available on the support site, just like recommended drivers page and sconfig variables.
Daniel
Adam Glick
on Oct 4, 2012 at 7:24:42 pm
*deleted*
Daniel Esperanssa
on Oct 5, 2012 at 1:09:38 am
This absolutely correct.
Sorry for having forgotten, Adam :-)
Daniel
