Tangent Element jog wheel strange behaviour
COW Forums : Assimilate Scratch
Pedro Conforti
on Aug 28, 2012 at 3:34:43 pm
Hey,
I am experiencing a very weird Scratch behavior when trying to use the Tangent Element jog ring, and would like to know if I am the only one.
First, I can't seem to find a way to jog backwards, only forward. But even this works strange, because it's just a matter of touching the wheel and it starts playing forward like on "play". To make it stop I have to "jog forward", but it only stops the motion, it doesn't actually move backwards.
On matrix > settings > configure panels, I have tried all combinations I could think of envolving the wheel (control number 0000d1012) and the commands "JogFwd" and "JogRev", including different mappings (0, 1, 2) and scales (1 and -1).
Nothing helped. Any ideas?
Also would love to see a suggestion for using the jog wheel trackball on Scratch, and also its LCD (oops, OLED) display, which so far is blank in my setup for lack of ideas.
Pedro
Pedro Conforti :: Colorist
Link Digital
Mac Pro 8 core 2.26Ghz 48Gb RAM
OSX 10.6.8 (Snow Leopard)
GTX 570 2.5Gb
Tangent Element
Decklink HD Extreme 3D
Matthias Aderhold
Re: Tangent Element jog wheel strange behaviour
on Aug 29, 2012 at 7:24:42 am
I think, there may be something wrong with your cs_mappings file.
The default mapping works fine and shows everything needed on each display.
You can find it under C:/Program Files/Assimilate/Settings.
There's a cs_mappings_element.xml - copy it to
C:/Program Data/Assimilator/Settings and rename it to "cs_mappings.xml".
Now make sure the selected Scratch-User dosen't bring his own mappings
(stored under C:/Program Data/Assimilator/User/cs_mappings.xml).
If this is the case and you want to keep them, just create a new user - it will
by default use the cs_mappings file you just copied.
If that doesn't help, you might have found a bug inside the Tangent Firmware on the panels,
which can occur on FW-versions earlier than 1.1.9.
There should be a fix for it available from Tangent - but you have to contact them via support-address.
Hope this helps^^
Mazze
Pedro Conforti
on Aug 30, 2012 at 7:06:22 am
Hey Matthias, thanks for the reply.
Actually my real problem is only about the jog wheel; all the Element's displays work fine. I as just looking for sugestions on what to do with the display above the jog wheel, since I couldn't think of any... :)
Anyway, I have been looking at these map files before and will check them again... could be something there indeed. I only worry about losing any of my carefully crafted mappings, but guess I can make backup copies before messing with them.
Best,
Pedro
Link Digital
GTX 570 2.5Gb
Tangent Element
Matthias Aderhold
on Aug 30, 2012 at 7:16:48 am
Sure you can - make a copy of your User under
C:/Program Data/Assimilator/User/*Username*
and copy it back if your new settings are messed up ;-) .
Chris Rose
on Aug 31, 2012 at 3:38:26 pm
Hi Pedro,
You can also try putting the panel into test mode (see the user manual you can download from our website for full details).
To do this plug the panel into a computer that isn't running our Hub software or isn't running any colour grading software that uses the panel.
When you see the Element-Mf logo come up on the display, press the 'A' button (you may need to wait a couple of seconds before pressing to give the panel time to boot).
You should now see a screen that lists all firmware version etc.
Turn the jog wheel and you will see the encoder value from the jog displayed. It should go + if you turn it to the right, and - if you turn it to the left.
Let me know how you get on. You can reach me via the Tangent support email address.
Cheers,
Chris
