Scratch and PRoTools MBox
COW Forums : Assimilate Scratch
Bill Claghorn
on Jul 17, 2012 at 12:43:04 am
I have two systems, one with ProTools and MBox and the other plain.
Scratch works fine on the plain system.
The system with the MBox hangs when play is started. I am not using the MBox for anything. I get Scratch failure to load MBox drivers in the Scratch Log file.
Is the MBox causing failure to play (hang) or should I look elsewhere?
Matthias Aderhold
Re: Scratch and PRoTools MBox
on Jul 17, 2012 at 10:29:01 am
Which audio-device have you selected in the Mixer's settings?
If the Mbox is selected, turn it off, or use the onboard sound to see, if that fixes the playback-issue.
Also scopes turned on have quite some impact on playback performance, you might turn them off, too, or set to half-res.
The two systems are identic regarding their hardware, I suppose?
© 2018 All Rights Reserved
