Adding titles
COW Forums : Assimilate Scratch
Julian Argentina
Adding titles
on Mar 13, 2012 at 5:28:27 pm
Hello, I'd like to know how can add titles made in tiff with alpha channel.
with layers maybe?
Matthias Aderhold
Re: Adding titles
on Mar 14, 2012 at 11:39:05 am
If done with Tiff+alpha,
you can add them as a scaffold onto the shot, as well as onto your whole Output/CONstruct.
Therefore you go to CONstruct ==> Output, select your (derived) output and go into Player - if you create a scaffold here, this lies upon the whole output. You can load your TIFF-sequence via the Texturemenu.
Otherwise you can use the Burn-In Plugin for titling (but doesn't work with tiff-files, obviously).
© 2018 All Rights Reserved
