Ultrascope in a box running Scratch
COW Forums : Assimilate Scratch
VIEW ALL   •   PRINT   •   NEXT >>
David Phillips
on Sep 16, 2009 at 8:32:44 pm
I am wondering if it is possible to run Ultrascope on its own video card in a PC that is also running Assimilate Scratch on another GPU.
thanks,
david
Bob Zelin
Re: Ultrascope in a box running Scratch
on Sep 16, 2009 at 11:51:00 pm
the bottom line is that if you do not have the exact required graphics card specified by Blackmagic, it's not going to work. With that said, I am unfamiliar with any of the super hi end NVidia graphics cards that Assimilate specifies that are compatible with the Ultrascope.
Everyone says "but this is a $2500 graphics card " ! Tough noogies.
Get the recommended graphics card, and your Ultrascope will work wonderfully (of course, Scratch will not).
Bob Zelin
Simon Blackledge
on Sep 17, 2009 at 8:55:23 am
I'd say no. Scratch is highly optimised. having another app run in the background would probably upset it.
if you have a free x1 slot for the scopes and a 16x for the gfx card try it.
If it doesnt you'll just have to build a pc.
Though if id did work you may struggle to get support through either companies.
s
Sean Donnelly
on Sep 17, 2009 at 12:16:53 pm
My guess would be yes, but not at the same time, as Simon said. BM says ultrascope will work with the quadro 4800, which as I recall is one of the ones that scratch can use, but from my experience with speedgrade gpu based apps get mad when something else tries to access it. I guess you could try to run a lesser GPU in the same machine and somehow direct ultrascope to use that, but you'd be sacrificing 2 slots in your scratch box, probably something you'd rather not do.
-Sean Donnelly
Digital Supervisor, SFI
Simon Blackledge
on Sep 17, 2009 at 1:28:39 pm
Yea sorry. To clarify I was talking about, at the same time. As in using the U_Scopes to monitor Scratch output.
s
