CONStruct Merge?
COW Forums : Assimilate Scratch
Julian Argentina
CONStruct Merge?
on Mar 1, 2012 at 9:12:24 pm
Hello, I´m a new user of scratch. I´d like to know if I can merge various CONStruct in a new single one. I have various reels of a feature film and we want to see it continuosly.
Matthias Aderhold
Re: CONStruct Merge?
on Mar 2, 2012 at 8:19:10 am
Don't know if this exact feature exists, but I would try to do a search onto the group / project, containing all relevant clips and search for something trivial, every clip has (or no search cirteria at all... might also work).
After hitting "search" it will give you a new (temp-)CONstruct, including every found clip, which you can just copy (Alt-Drag CONstruct - rename) and make it a "normal" CONstruct.
Then sort all clips in this CONstruct based on TC - I'm not at a box right now, but this might work^^.
Julian Argentina
on Mar 2, 2012 at 2:44:18 pm
Hi, thanks! I´ll try to use that way.
Another issue scratch makes a kind of scanning issues (looks more when images moves a lot) on the image playback on both monitors, we are using a quadro 4000, any idea?
Matthias Aderhold
on Mar 2, 2012 at 3:12:10 pm
Quadro 4000 (under assumption you're using the correct driver's version) is fine - are you able to upload a screenshot?
Julian Argentina
on Mar 2, 2012 at 3:15:41 pm
I´m not sure if it´s the correct driver, it´s the late one that I could download. I need a specific one version driver?
thanks!
Matthias Aderhold
on Mar 2, 2012 at 3:20:49 pm
Depends on your Scratch Build and OS you're using.
There's a nice chart on the Assimilate-support-site, listing every
Scratch build, OS and corresponding drivers for each combination^^.
Julian Argentina
on Mar 2, 2012 at 3:31:25 pm
Thanks, I just ask for register, I´ll check the driver version first at all.
all the best
Daniel Esperanssa
on Mar 9, 2012 at 9:43:12 am
Hi Julian,
Create a "Final" Construct.
In Reel 1 Construct Output menu, "Add a single Output".
Select it and "Copy Selected"
Navigate to Construct "Final" and "Paste Shots" into slot 1.
Do the same way with Reel2, drop into slot 2 etc etc, until you get the ie:6 reels outputs in the "Final" Construct.
Done.
Bonus Advantage: any grade update on any of the shots of Reels 1 to 6 constructs will be updated in "Final" construct, as it contains references to all the outputs.
Isn't that cool ???
Cheers,
Daniel
Daniel Esperanssa | Assimilate Europe Ltd.
Julian Argentina
on Mar 9, 2012 at 11:36:09 pm
Hi Daniel! Thanks a lot! its sounds very easy, I'll do it!
all the best!
