AE CS5 and Assimilate Scratch and LUT...
COW Forums : Assimilate Scratch
VIEW ALL   •   PRINT   •   NEXT >>
Brandon Lindquist
on Aug 1, 2010 at 1:47:32 am
There isn't an Assimilate Scratch forum, but maybe this will work.
Before I get to my problems let me just say what we need to do.
1) We need to color grade our RED (.r3d) footage in Assimilate Scratch.
2) Then save the LUT out of Scratch as a .3dl file.
3) In AE CS5, "Apply Color LUT".
Boom, supposedly a fast an easy way to grade footage and work with it in AE without having to export.
Our only snag is Appling the LUT in AE. AE just simply says its unable to apply the LUT. I know it needs to be "Integer" and not "Floating Point" according to this...
http://help.adobe.com/en_US/aftereffects/cs/using/WS725e431141e7ba651e63e3d...
However, I see no indication in Scratch that the setting of such items is available.
Anyone have any insight?
Todd Kopriva
Re: AE CS5 and Assimilate Scratch and LUT...
on Aug 2, 2010 at 4:30:53 pm
The current version of After Effects CS5 is not able to use these LUTs. Though I can't comment explicitly on when updates will occur or what features and fixes might be in them, I can say that we are working on a fix that would add support for Assimilate Scratch LUTs.
Technical Support for professional video software
After Effects Help & Support
Premiere Pro Help & Support
Brandon Lindquist
on Aug 2, 2010 at 9:57:02 pm
(Just as a test a colored the footage to be completely red.)
I figured out that if you change all the setting in Scratch to 10bit AE CS5 will import the LUT but it seems to do it with some kind of color shift.
Would changing the footage interpretation or the source setting in some way fix this?
Todd Kopriva
on Aug 3, 2010 at 3:18:50 am
As I said in my previous post, the current version of After Effects is not able to use these LUTs. Pay attention for future updates.
Brandon Lindquist
on Aug 3, 2010 at 3:57:15 am
Gotcha, thanks!
Todd Kopriva
on Sep 3, 2010 at 11:40:39 pm
The After Effects CS5 (10.0.1) update is available:
http://bit.ly/9ex5Cf
This update should address this issue. After you've installed the update, please let us know whether it works for you.
If you have any problems with the update, or if you have bugs to report after you've installed the update, please let us know through the usual channels:
http://bit.ly/93d6NF
