"new tracks were created for each device"
COW Forums : PluralEyes
Joshua Guerci
on Feb 8, 2017 at 1:12:54 am
I'm using PluralEyes 4.1.1 and I am trying to sync footage from my C100 with audio from H6N. I import everything just fine but when I go to sync it says ""4 tracks contain clips from several devices, new tracks were created for each device" and then creates a separate track for each clip. Its fine if I'm only syncing 2-3 audio clips but if I'm syncing 50 audio clips such as from a narrative shoot, its disastrous! Any ideas? Do I need to upgrade my PluralEyes?
http://www.filmless.com
Kevin Carlson
Re: "new tracks were created for each device"
on Feb 14, 2017 at 2:47:19 pm
I think you can disable its ability to create new tracks can't you?
I've had so many tickets with them about v4 it's ridiculous, but I think they are working on the bugs and have been responsive.
Urten Ekran
on Apr 5, 2017 at 10:45:55 pm
I have the same issue but I figured out a workaround:
Put all your files in a timeline in Premiere Pro (maybe this also works with other NLE) and save it as a xml. Then import the xml into Plurleyes and sync.
Or just use Pluraleyes 3
