Will it blend...
COW Forums : PluralEyes
Eric Santiago
Will it blend...
on Jan 27, 2016 at 8:39:52 pm
Can PluralEyes do this.
I have folder with over 500 Broadcast WAV files using SoundDevices 744T.
These were from a full feature shoot.
We have a rendered picture lock QuickTime movie with audio.
Editor used proxy files (RED timecode synced with Broadcast WAV exported as h264) for the rough cut and now we would like to populate a timeline with the Broadcast WAV files.
Is this possible.
Kalle Kannisto
Re: Will it blend...
on Jan 29, 2016 at 4:14:10 pm
Pluraleyes is designed to be used before editing. I assume the high-quality audio clips are much longer than the edited rough audio, which is likely to cause issues.
I'd say the only way to know for sure is to download the trial, try it and see what happens.
