FCPX Import XML
COW Forums : PluralEyes
David Edwards
FCPX Import XML
on Nov 5, 2015 at 2:08:22 am
So I've been able to export successfully and import clips and multicam clips to FCPX on the same machine with the same absolute path. But when trying to export a lot of synced clips for use on another machine with a different file path to media, the import fails and doesn't allow relinking, with "the item could not be read" error. Is there some kind of setting that a allows export from Plural Eyes that won't fail if the filepaths aren't the same on the machine where import happens? Thanks!
