Problem with "mark as synchronized"
COW Forums : PluralEyes
Patrick Spadrille
on Nov 19, 2014 at 7:28:45 pm
Here is my problem. The audio and the video coming from my camera are not in perfect sync. The audio is 3 frames sooner than the video. It's a hardware problem. So, the synchronisation in Plural eyes with the audio recorder is also not in sync since plural eyes sync the audio from the audio recorder with the audio coming from the camera. Here is what i want to do :
1 - Sync with plural eyes
2 - Mark all audio as unsynchronized
3 - Move all the audio clips 3 frames forward
4 - Sync one by one the audio and the corresponding video by using "mark as synchronized".
The BIG PROBLEM is in step 4, when i select my first 2 audio and video clip and select "mark as synchronized", these 2 clips are indeed synchronized BUT all the other clips (audio and video) moves so that there are not gaps between them and doing that i loose all the rectified (+ 3 frames) synchronized clip that i had.
My question : is there a way to mark 2 clips as synchronized without having the other clips moving? Another question : do you see a better workflow to solve my 3 frames unsync problem?
