sync failure - fcp 7, two prores clips
COW Forums : PluralEyes
Tom Sanders
on Sep 9, 2011 at 9:25:55 pm
I had pretty good success with the trial version of PluralEyes, but since purchasing it, I can't get a single clip to sync.
Sources are two prores quicktimes; one with audio from a pro mic in a vo booth, the other from a flipcam (also in the booth)shooting video from 3-4 feet away, using a camera mic. Good levels and no distortion on either track.
Both sources were converted to prores, 23.98, 16 bit, 48k, prior to importing into FCP 7. The audio-only track has had a video element added to it in FCP, exported, then reimported so that the clip would be seen as one by FCP.
One track is mono on two channels, centered; the other is mono on a single track.
I tried, in order:
- 'no options'
- try real hard
- level audio
- markers
Complete fail every time. No error messages, it just doesn't sync the clips.
Any ideas?
PluralEyes v2.0.2
FCP 7.0.3
OS 10.6.8
Mac Pro
© 2018 All Rights Reserved
