Syncing raw audio with an edited sequence with on-board audio
COW Forums : PluralEyes
Pieter Viljoen
on May 31, 2013 at 6:26:04 am
Audio engineer did not slate, did not call takes, nothing. I got a series of folders which were not named in any way that correlates to the many scenes that were shot, and in fact, none of the files are uniquely named (every folder starts at audio000.wav)
We had to start cutting because of time constraints, but do you think it will be possible to export an AAF, then throw about 50 audio files (all of which are mono) into Pluralize? What do you think is the best thing I can do in this situation? Picture lock is probably 4-5 days away.
Thank you so much
Pieter
