Worx4 X - a way to trim Project media
COW Forums : Apple Final Cut Pro X Debates
Craig Seeman
on Apr 21, 2017 at 3:10:14 pm
People have been asking for this feature in FCPX for a long time. It took a third party to do it.
Of course Apple will promptly including it in the next major update 😏
Worx4 X
Note the limitations though. This may well be the same things Apple is up against (and therefore haven't implemented yet).
Noah Kadner
Re: Worx4 X - a way to trim Project media
on Apr 21, 2017 at 4:35:56 pm
Worx works like a charm and is incredibly fast. If you are heavy on shooting ratio and light on storage space, this is the app you're looking for.
Noah
FCPWORKS - FCPX Workflow
FCP Exchange - FCPX Workshops
XinTwo - FCPX Training
Craig Seeman
on Apr 21, 2017 at 7:46:22 pm
Although I'm concerned by
Worx4 X will not currently trim either MXF, M4A(AAC), AC3, CAF or mp3 media files, the whole file will be copied.
Since that would mean Sony cameras which use MXF aren't trimmed.
WAV or AIFF files will not be trimmed if the preferences are set to 'Copy audio files without losing metadata'. Please set this option on first installation.
This too. It's why I think Apple hasn't implemented it. I believe there are challenges to trimming certain formats without losing metadata.
Noah Kadner
on Apr 21, 2017 at 11:45:53 pm
Probably more because all of those long-GOP formats lose major quality when re-encoded. I don't follow how that's Apple's fault. If every camera recorded to ProRes instead of H.264 we'd be all set.
Noah
Jeremy Garchow
on Apr 22, 2017 at 12:28:03 am
Long GOP I understand why it doesn't trim (and honestly, those are usually smaller files anyway), but MXF files like XAVC that are intraframe, would be nice to have.
I really want to use this product as I really need it. I currently use Resolve for this and would love something much simpler, But not having MXF is a show stopper. What would be really nice is a trim and transcode to, say 444 or XQ.
Optimizing everything first, sort of defeats the purpose of trimming.
Walter Soyka
on Apr 22, 2017 at 10:19:51 am
Long GOP media could be trimmed losslessly. You'd just have constrain the trimming to GOP boundaries.
Walter Soyka
Brett Sherman
on Apr 22, 2017 at 9:08:45 pm
Is this any different than ClipExporter 2? That's what I use for this purpose. And the non-MAS version can handle MXF files.
EDIT: Nevermind, now I see it creates an XML file to reimport to FCP X, which ClipExporter doesn't.
Brett Sherman
One Man Band (If it's video related I'll do it!)
I work for an institution that probably does not want to be associated with my babblings here.
Craig Seeman
on Apr 22, 2017 at 1:03:45 am
[Noah Kadner] "I don't follow how that's Apple's fault."
It's not Apple's fault but given that many cameras record in Long GOP, Apple decided not to complicate things (IMHO). Hence no media manage feature.
Although I'd point out there are Intra Frame MXF codecs so not all MXF is Long GOP.
Of course what Apple could do is allow you to Optimize (make ProRes) XDCAM variants (XAVC-L for example) which it doesn't do now.
If you could convert ALL VIDEO to ProRes then they could implement Media Management.
Noah Kadner
on Apr 22, 2017 at 1:49:57 am
If all you want is transcode to ProRes you can do this yourself with any number of dailies prep apps. I'd love it if FCPX made my dinner too.
Noah
andy patterson
on Apr 22, 2017 at 8:37:20 am
[Noah Kadner] "Probably more because all of those long-GOP formats lose major quality when re-encoded. I don't follow how that's Apple's fault. If every camera recorded to ProRes instead of H.264 we'd be all set."
H.264 uses much less hard disk space and requires much less sustained data transfer speeds than Pro Res. A lot of SD cards will not sustain writing speeds to record Pro Res at 4k. H.264 gives a good clean image without need for a lot of storage space or super fast storage type media.
Tom Sefton
on Apr 22, 2017 at 9:20:58 pm
But it's only 8bit? Not really comparable
Co-owner at Pollen Studio
http://www.pollenstudio.co.uk
Robin S. Kurz
on Apr 22, 2017 at 11:20:51 am
[Craig Seeman] "Note the limitations though. This may well be the same things Apple is up against (and therefore haven't implemented yet)."
I'd say you're right.
Personally this is nothing I need or miss, since I archive archive copies of all cards and media anyway and simply delete all media before archiving the finished library. Which then is obviously very small. This wouldn't save me anything in my workflow.
[Jeremy Garchow] "trim and transcode to, say 444 or XQ."
Huh? Wait. Isn't the whole point of this to save space??
And apparently some people haven't heard of the differences between ProRes' and H.264 color space for starters, or that there are already endless cameras that record to ProRes to SD just fine, but oh well.
- RK
____________________________________________________
Deutsch? Hier gibt es ein umfassendes FCP X Training für dich!
Jeremy Garchow
on Apr 22, 2017 at 1:37:49 pm
[Robin S. Kurz] "Huh? Wait. Isn't the whole point of this to save space??"
Yes.
The point, for me, would to reduce many hours of footage to many minutes of footage to get over to color grade facility. I would not use this app for archive for me, as I archive everything.
What I don't do, is send all the media for a job to color grade.
I use Resolve for this, and I'd love a simpler way. Resolve is able to trim, transcode, and add handles. Typically, the media, even at 4K 444, reduces down from TBs to tens of GBs even allowing internet transfer of spots to the grading facility which is more convenient.
X2Pro, made by Marquis, already trims and embeds Audio to AAF flawlessly. Obviously, this is a much bigger task to handle with video, but I'm confident they can figure it out eventually. :)
Oliver Peters
on Apr 23, 2017 at 4:05:24 am
[Jeremy Garchow] "but I'm confident they can figure it out eventually"
Especially since they used to be able to do that with FCP7.
Oliver
Orlando, FL
http://www.oliverpeters.com
Jeremy Garchow
on Apr 23, 2017 at 4:46:13 pm
[Oliver Peters] "Especially since they used to be able to do that with FCP7."
I was talking about Marquis Broadcast (the developer) being able to trim audio media (including mp3 by converting to PCM) with X2Pro. Eventually, I hope, they can apply this to Worx. Unifying a trimmed version to one codec would be excellent for my needs.
As far as FCP7, Quicktime was a beast, and still hasn't been fully replaced. My guess is that MXF files can't be written correctly, or maybe Marquis just isn't there yet. It's not an easy task.
Robin S. Kurz
on Apr 24, 2017 at 8:03:33 am
And how many long-GOP and/or MXF formats did 7 ever support? Oh, right… 😏
- RK
