Translations for Avid editors
COW Forums : Apple Final Cut Pro X Debates
Trevor Asquerthian
on Nov 2, 2016 at 8:58:23 am
In case they are useful to anyone trying out 10.3... please do add any others, or links to where this is done already
Avid Project = FCPX Library
Avid Folder = FCPX Event
Avid Sequence = FCPX Project
Avid Command Palette = FCPX Keyboard Customisation = ⌥⌘ K (then 3 x tabs to get to search box)
Avid Project Window = FCPX Library Browser = ⌘ 1
Avid Timeline = FCPX Timeline = ⌘ 2
Avid Program Monitor = FCPX Viewer = ⌘ 3
Avid Source Monitor = FCPX Event Viewer = ⌥⌘ 3 ( ^⌘ 3 to show/hide)
Avid Effects Palette = FCPX Effects Browser = ⌘ 5
Avid Mark In = FCPX Set Range Start = I
Avid Mark Out = FCPX Set Range End = O
Avid Mark Clip = FCPX Select Clip Range = X
Avid Top = FCPX Trim Start = ⌥ [
Avid Tail = FCPX Trim End = ⌥ ]
Avid Head Fade = Not there yet, closest is FCPX Toggle Audio Fade IN
Avid Tail Fade = Not there yet, closest is FCPX Toggle Audio Fade Out
Avid Add Edit = FCPX Blade = ⌘ B
Avid Export = FCPX Share = ⌘ E
Avid Timewarp/Motion Effect = FCPX Retime = ⌘ R ( ⌥⌘ R to reset)
Avid Select Trim Sides = FCPX Select Edges = [ ] \ (add ^ for video, ⇧ for audio)
Noah Kadner
Re: Translations for Avid editors
on Nov 2, 2016 at 12:24:38 pm
Folder =Event is not accurate from a metadata/workflow perspective and would lead a poor Avid editor down precisely the wrong path toward learning the advantages of X over all ofher NLEs. They are fundamentally different in functionality. One is a container with zero awareness of its contents while the other is a live metadata placeholder.
Noah
FCPWORKS - FCPX Workflow
FCP Exchange - FCPX Workshops
XinTwo - FCPX Training
Oliver Peters
on Nov 2, 2016 at 12:54:44 pm
More correctly, it should be Avid Bin = FCPX Event.
- Oliver
Orlando, FL
http://www.oliverpeters.com
Trevor Asquerthian
on Nov 2, 2016 at 10:24:20 pm
[Oliver Peters] "
More correctly, it should be Avid Bin = FCPX Event"
You may be right there, although FC Events = AV Folders and FC Folders = AV Bins, kind of
FCPX Smart Collections = What we have been waiting for from Interplay for about 10 years
Trevor Asquerthian
on Nov 2, 2016 at 10:25:25 pm
[Noah Kadner] "They are fundamentally different in functionality."
The whole thing is fundamentally different. I was attempting to verbalise my understanding. Happy to take crit, obvs.
Jeremy Garchow
on Nov 2, 2016 at 3:45:03 pm
[Trevor Asquerthian] "Avid Command Palette = FCPX Keyboard Customisation = ⌥⌘ K (then 3 x tabs to get to search box)
Weird. My search box is active as soon as the kb panel opens.
[Trevor Asquerthian] "Avid Add Edit = FCPX Blade = ⌘ B"
I find it more helpful to map blade to 'B'. I then map the blade-all function to ⌘B, and the Blade tool (which switches the Select Tool to a blade, then you click to blade) to ⇧⌘B. I rarely use the blade tool as a mode, but I blade all the time (obviously). Mapping the function to B is much faster and easier, especially with the new shortcuts of Select Above/Below in 10.3.
Trevor Asquerthian
on Nov 2, 2016 at 10:30:17 pm
[Jeremy Garchow] "My search box is active as soon as the kb panel opens."
Mine opens up with the command set dropdown selected (rMBP OSX 10.11.6 FC 10.3 - Build 295518)
[Jeremy Garchow] "I find it more helpful to map..."
Yes, I have preferred shortcuts - mainly to match my normal hodge-podge of Avid / FCP7 / Premiere Pro / Sony 9100 / GVG muscle memory & preference to keeping my right hand free... I felt it was better to state the default command set.
Which has, by and large, had a good deal of thought put into it.
