Apple Loops for Soundtrack Pro
COW Forums : Apple Final Cut Pro X Debates
James Ewart
on Oct 29, 2016 at 11:30:49 am
This is kind of pertaining to the update ...
I have hung onto my Apple Loops for Soundtrack Pro Folder (checked and license was in perpetuity with FCP7 so think I'm on safe ground as I am still running FCP7. I successfully imported Apple loops for Soundtrack Pro into previous iterations but in this update they have disappeared and I would like to import them again.
Where should I pick so that they appear for every project and don't have to import into a specific Event every time?
Ideally I'd like them all to be just sitting there as they were before.
Any thoughts?
http://www.jamesewart.co.uk
Mark Dobson
Re: Apple Loops for Soundtrack Pro
on Oct 29, 2016 at 1:43:31 pm
Hi James,
I'd recommend creating a specific library for your loops and then have that sitting in the background for when you want to drag them into your current library / event. I do this for my stockpile of BBC sound effects.
How are you getting on with 10.3 apart from this issue? Can't wait to install this update but need to finish a large project first.
Mark
James Ewart
on Oct 29, 2016 at 1:53:14 pm
Great idea thank you.
Haven't quite got to grips with the roles functionality yet but getting there and looks promising. Not sure I've noticed any downside other than my eyes don;t seem to like the UI being like nighttime all the time.
Cheers Mark
Mark Dobson
on Oct 29, 2016 at 2:00:40 pm
I've ever really embraced roles but think this new iteration could get me involved in the workflow.
Generally 10.3 looks like a rich reward for those who have persevered with FCPX through all it's changes since its fitful birth all those years ago.
Mark
James Ewart
on Oct 29, 2016 at 2:08:35 pm
Absolutely but it also kind of reinforces the view of the people who said it was software 'in development" and not fit for purpose.
Thanks for that excellent tip again. Feeling like it's a much better solution than before already.
Warren Eig
on Oct 29, 2016 at 5:35:27 pm
I brought all the loops into iTunes as well as all my other sound effects libraries. Now when I need to do some sound design, I open iTunes and audition what I want. When I find an FX I like, I just drag it into a bin/event called sound effects.
Warren Eig
O 310-470-0905
email: info@babyboompictures.com
website: http://www.BabyBoomPictures.com
For Camera Accessories - Monitors and Batteries
website: http://www.EigRig.com
James Ewart
on Oct 29, 2016 at 5:54:59 pm
Thanks for this. Love hearing other peoples' solutions.
In Itunes it did not seem to organise them be folder when I tried this whereas a new Library creates a nice bunch of Keyword collections so you can still find everything according to what folder they were in.
I may not be that proficient with Itunes however.
Warren Eig
on Oct 29, 2016 at 8:28:54 pm
I tagged everything as I added so they show up as albums, sort of like folders. Plus I can search in iTunes with a few words and it finds things for me. I can make smart playlists to search. Like you can in FCPX but everything lives in one place.
Warren Eig
O 310-470-0905
Marco Spirig
on Nov 6, 2016 at 8:17:57 pm
I copied the Loops into one of the two "proper working" folders ("Macintosh HD/Library/Audio/Apple Loops/Apple/iLife Sound Effects" and/or "Final Cut Pro Sound Effects"). After e few seconds of indexing, the loops appeared as expected.
James Ewart
on Nov 7, 2016 at 7:27:07 am
Thanks for this great.
This worked for me wth previous version but the folder does not appear when I drop it it into either of these folders in version 3.0
Is either one preferable?
James Ewart
on Nov 7, 2016 at 8:02:05 am
Okay great thanks for this. Got it. Couldn't find the folder but now worked perfectly now I have moved it into Sound Effects from previous location. That said creating a new Library for sound effects is also a great solution because it's easier to organise.
Thanks both for the input.
James Ewart
on Oct 30, 2016 at 3:23:17 am
I think I'm being a bit of a berk with this Itunes. How exactly do you add these files as my version dos not seem to like the file format of the loops.
