I have a question but I didn't type it because videos are easier! Please watch
COW Forums : Apple Final Cut Pro X Debates
Tim Kusel
on Sep 29, 2016 at 10:46:03 pm
Hope this makes sense to whoever watches it. Thanks for taking the time!
Tim
Brett Sherman
Re: I have a question but I didn't type it because videos are easier! Please watch
on Sep 29, 2016 at 11:29:37 pm
In the Inspector, click on the video tab. Then scroll down to Spacial Conform. Change it from "Fit" to "None". That should do it. The risk with scaling is that unless you do it exactly right your pixels won't line up exactly. Therefore it could blur the image slightly.
Brett Sherman
One Man Band (If it's video related I'll do it!)
I work for an institution that probably does not want to be associated with my babblings here.
Tim Kusel
on Sep 29, 2016 at 11:32:10 pm
Thanks for the response.
With this method though, I won't lose any pixel quality at all?
Brett Sherman
on Oct 1, 2016 at 1:40:57 am
Assuming your horizontal pixel dimension is the same in each, it should be a pixel to pixel match. So no, you won't lose any quality.
Brett Sherman
Tim Kusel
on Oct 1, 2016 at 1:43:36 am
Appreciate it a bunch man. Thanks!
Gary Huff
on Oct 3, 2016 at 11:32:34 am
[Tim Kusel] "Hope this makes sense to whoever watches it."
Whatever your issue was, it won't sure up in search engine results when someone with a similar issue is trying to find a solution. Won't you think of the children?
Tim Kusel
on Oct 3, 2016 at 6:22:18 pm
You're absolutely right... How selfish of me!
It was however, my first ever post in these forums, so I'm kind of a noob.
Can I change my post so it can show it up search engines?
