Re: 2ndary storylines and dissolves: why can't these things be done in FCP X???
COW Forums : Apple Final Cut Pro X Debates
Nicholas Natteau
on Jul 5, 2011 at 6:00:52 pm
[1] Why can't Secondary Storylines be moved in the Timeline? I find that you have de-storyline the clip in order to move it.
[2] Why can't Dissolves be copy pasted from one secondary story to another to another? Say for example that I have a bunch of stills as secondary storylines attached to the main storyline in the timeline. Say that I want to add a half second dissolve to all my stills. I'm unable to copy the first dissolve and paste it to all the others (like I could in FCP7).
Any workarounds for this?
Simon Ubsdell
on Jul 5, 2011 at 6:26:56 pm
[Nicholas Natteau] "
[1] Why can't Secondary Storylines be moved in the Timeline? I find that you have de-storyline the clip in order to move it."
You can drag a secondary storyline to wherever you want it in the primary storyline and it will perform an insert edit. It will of course cease to be a storyline in itds own right at this point but then you wouldn't expect otherwise. You should use compound clips if you want a grouping to stay together in the primary storyline.
Simon Ubsdell
Director/Editor/Writer
http://www.tokyo-uk.com
